Wiring infor for solar needed
Scotia
Not a new build but uprating existing setup.
Purchase a Dethleffs last year which was fitted with a PV Logic 120w panel going to a 10 amp PV Logic charge controller which has two outlets one for cab battery and the other for the leisure batteries which are 2 X Varta 95ah AGM.
The two + from the controller connect onto a red and a blue wire which are fused, both - connect to the brown which then connect into the Schaudt Elektoblock EBL 102 ( I cant find an english instruction manual version of this online) which I understand when charging gives preference to the leisure battery and a float charge to the cab battery, then there is the Schaudt Booster WA 121545 (which I have an english manual ).
Now to mess things up I purchased a second PV Logic 120w panel and have wired in parallel, luckily when the van was built there had been a second pair of 6mm wires run alongside the pair in use so was an easy fit the panel came with a 20A PV Logic controller which also has two points for the battery one for cab the other for leisure.
I have a Victron smart MPPT 75-15 controller which I would like to fit but this only has a single output for battery, on contacting the company to see what can be done the reply was to use a Votronic device I have aske him to clarify but it takes an age to get a reply typically one reply per day. Doing a bit of research I see they supply a Cyrix battery combiner for split charge.
Has anyone connected a MPPT to the EBL 102 and how did you go about it?
Victron smart MPPT 75-15 controller is good for 1 x 120w panel but not 2 or will be at its limets on full charge . As my 2 100w was 60 to 70 volts.at neary 15 in sires
amps
Scotia
Hmm took advice from the supplier and they also do installations, will message them again in the morning.
Scotia
amps
This was the reply after consulting his colegue when I queried his choice,
Hi Sam,
The 75/15 controller can take up to 75V, however we would tend to allow a 25% allowance so two solar panels at 22.4V each would be fine on this controller.
Many thanks,
Matthew Jukes
